Rendering quality question
Posted by Dave Petteruto on November 15, 2005 at 5:10 pmHi All,
I am using Vegas 5 and my question is this: If I render a Vegas file to an AVI file then import that AVI file along with others back into vegas and render the whole thing to an mpeg2, how much quality will I be losing using this workflow? The original Vegas build consists of photos, title pages, captured digital video & music.
DaveDave Petteruto replied 20 years, 10 months ago 4 Members · 5 Replies -
Gary Kleiner
November 15, 2005 at 6:46 pmTheoretically, you would loose some quality compared to rendering the Mpeg from an earlier generation and/or original material. However, the difference may well be negligible in the real world.
Best way to tell is to do some test renders.
Gary
Jongira
November 15, 2005 at 7:33 pmImport the .veg vegas project file you made into the new project (easiest is to drag and drop it), instead of importing the rendered file. Then when you render the new project the original project will be rendered from the source, and you’ll avoid second-generation losses. – Jong
Donatello
November 16, 2005 at 12:17 amif you rendered out using the DV template ( 4:1:1) color space .. then bring that into Vegas to render a mpeg for DVD (4:2:2) color space = you lost 1/2 of the color info plus you have introduced stair stepping on all line edges that are not perfectly horizontal or vertical then if you rendered out of the TL (edited clips, photo’s text) to mpeg 2 …
if you need to make different files you could render out of Vegas using the dv template – custom – video then in format choose sony YUV ( 4:2:2 color space) codec .. then use that to render out to your mpegs, dv avi, wmv , QT etc …
Dave Petteruto
November 16, 2005 at 1:50 pmRe. Info from donatello:
“if you need to make different files you could render out of Vegas using the dv template – custom – video then in format choose sony YUV ( 4:2:2 color space) codec .. then use that to render out to your mpegs, dv avi, wmv , QT etc …”Is this codec part of the Vegas 5 software package (can’t check now-I’m @ work) and what kind of quality loss will using this codec cause?
Dave
