Activity Forums VEGAS Pro Rendering Quality Problem!
  • Rendering Quality Problem!
    Posted by Stanly Dcosta on February 6, 2012 at 5:23 pm
    So I’ve just worked on this project for about a month now. Now that it’s finished; I’ve rendered it in HD and the video still comes out a little choppy and very little pixelated though in the preview when I’m editing I put the preview to Best and It’s CRISP clear, only when I render it the quality just goes down Hill!
    This film/project that I’m working on was shot in HD 720p.
    I tried rendering in 720P 1080P and still quality is bad!
    Also last summer I’ve been working on a project too but everything went fine, it was shot with the same camera that I’m using and I rendered it and it came out crispy clear. This time it’s not rendering it crispy clear… please help my deadline for this project is coming up!
    John Rofrano replied 14 years, 7 months ago 4 Members · 6 Replies
  • John Rofrano
    February 6, 2012 at 5:48 pm
    [Stanly Dcosta] “This film/project that I’m working on was shot in HD 720p. I tried rendering in 720P 1080P and still quality is bad!”
    If you shot in 720p you should not be rendering 1080p, you should only render as 720p.
    What are your project settings?
    What are your render settings?
    The more you can tell us about what’s settings you’re using, the better chance someone will see what the problem might be.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stanly Dcosta
    February 6, 2012 at 6:47 pm
    As of now my project settings are:
    HDV 720-25p (1280×720, 25.000 fps)
    Field Order: none
    Pixel Aspect ratio: 1.000 Square
    Frame rate : 25.000(PAL)
    Pixel Format: 8-Bit
    Resolution render quality: Best
    Motion Blur: Gaussian
    Deinterlace method: Blend Fields
    RENDER SETTINGS:
    Save type as : WMV
    Template : 5Mbps HD 720-25P
    Mode: CBR
    Image size: High Definition 1280×720
    Video Rendering quality: Best
  • Stanly Dcosta
    February 6, 2012 at 6:53 pm
    On Sony Vegas Preview the video looks HD Clear but after rendering the quality gets ruined.
    I’m not sure if it’s my settings or what.
    Because my last project came out really clear and i was very pleased with the results.
    I think i’m messing up somewhere…
  • Tyson Onaga
    February 6, 2012 at 7:12 pm
    Do you have a need to use Windows Mucked-up Video format? You’ll get much better results if you use one of:
    a. MainConcept MPEG-2
    b. QuickTime 7
    c. Sony AVC/MVC
  • Matt Crowley
    February 6, 2012 at 7:15 pm
    If you haven’t already tried it, then render your project using the Sony AVC format and the “Internet 720p” presets (25p if that’s definitely the source frame rate). That should give an MP4 file with pretty good quality for 720p or HD source.
    The general opinion here seems to be to avoid WMV unless you specifically need to use that format.
  • John Rofrano
    February 6, 2012 at 9:37 pm
    I agree that Sony AVC will give you a good encode. Your problem may just be your bitrate. If your camera shot 16Mbps HD and your rendering 5Mbps WMV that’s 1/3 the information. Sony AVC with 16Mbps should produce the same quality as your source. Even at 8Mbps it should still be pretty good.
    ~jr
