Activity Forums Boris FX rendering problems with rol titles
  • rendering problems with rol titles
    Posted by Paul Friedli on December 8, 2006 at 2:53 pm
    Hi
    I’m trying to create roll and crawl titles with graffiti, but the result is jittery when rendered in Media 100 v11.5 and 11.5.1 (producer and HDe)
    I’ve tried different codecs (m100i, DVCPro50 and DV) but the results are the same. I also tried playing with the settings in graffiti.
    Any suggestions
    Boris Yamnitsky replied 19 years, 8 months ago 3 Members · 2 Replies
  • Mark
    December 11, 2006 at 12:12 am
    TRy speeding up or slowing down the credits. Try changing fonts. Also in the preferences, make sure that you set 1:2:1 deflicker (I think that’s the name, am not in front of Boris at the moment) to on.
    Hope this helps
    Mark
  • Boris Yamnitsky
    December 13, 2006 at 11:00 pm
    Also make sure that your Render Fields As Frames or Better Quality Field Rendering preference is on in User Prefs. Exact name depends on the version of Graffiti.
