Activity Forums Boris FX Rendering problems with Boris Red 3 in Premiere Pro 1.51
  • Rendering problems with Boris Red 3 in Premiere Pro 1.51
    Posted by Madmax1234 on August 27, 2005 at 2:43 pm
    Hi guys.
    i am using premiere pro 1.51 with boris red 3.
    When make a transition with an 3D Object and map a video on the 3D object then is the preview allright, but when it is been rendered inside premiere the result does not looks right. The video is not in the right place of the 3D object or the aspect ratio is wrong.
    Do you have some ideas what i can do to get arround this error, maybe it is my fault.
    I am dispaired.
    Greets Max.
    Madmax1234 replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
