Activity Forums Adobe After Effects Rendering Problems: Animation
  • Rendering Problems: Animation
    Posted by John Russell on November 13, 2014 at 6:05 pm
    Hi I’d be very grateful of any advice!
    I’m having problems rendering out a 45 minute animation film, composed of 50-ish animated image series rendered in PS and still images, these are layered in AE and a few simple effects (opacity, size, location) have been added. The film has audio and will be projected at largish scale (6-8ft height)
    I have been rendering (in AE 6) with the following settings:
    H.264
    Quality: best
    Resolution: best
    size: 1920 x 1080
    frame rate 25
    profile: High
    Level: 5.1
    Bir rate 50
    Bit rate encoding CBR
    Audio Output: 48,000
    Audio codec: AAC
    Bitrate settings 320
    Problem is the final file size is huge 300+ GB and rendering time is 10-12 hours (I am less concerned about the render time – my main problem is the file size. Any suggestions of what setting to use to maintain quality but get a manageable file size so it will play on a media player.
    Would be grateful of any help.
    John Russell replied 11 years, 10 months ago 2 Members · 7 Replies
  • 7 Replies
  • John Cuevas
    November 13, 2014 at 6:53 pm
    Bit rate of 50, like 50Mbps is very high, your target bitrate should be more like 4.5Mbps with a max of 6. Also, I would take the AE comp, dynamically link it to Adobe Media Encoder and render it from there, you have a quite a few more options for compression.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Russell
    November 13, 2014 at 6:59 pm
    Johnny thanks a lot for that will try at 4.5 as you say and try to work out the dynamic linking. Thanks a lot.
  • John Russell
    November 13, 2014 at 7:02 pm
    Johnny do you have any compression suggestions?
  • John Cuevas
    November 13, 2014 at 8:08 pm
    Based on the little info you provided, your settings should work, with the adjustment to the bit rate. If you have the time(or access to a faster computer), I would suggest variable bit rate and change it to 2-pass(something you can’t do in AE).
    Also–and I forget this sometimes…just do a test, render 1 minute of the most complex portion of your animation and see how it looks, then if you need to make adjustments, make them and test again.
    Thinkck.com
  • John Russell
    November 13, 2014 at 8:26 pm
    OK thanks a lot for this I will do a few 1 minute tests. Thanks again.
  • John Russell
    November 13, 2014 at 8:27 pm
    Dave I”m projecting it at largish scale in an exhibition 6-8 feet high. playing it via media player.
  • John Russell
    November 13, 2014 at 8:28 pm
    Dave
    I’m projecting it in an exhibition at 6/8 ft high and via a media player.
