Activity › Forums › Adobe Premiere Pro › rendering problems
  • rendering problems
    Posted by Ruth Geva on May 6, 2011 at 10:24 pm
    I am working with premier pro 1.5
    I am having problems to render sequences. There doesn’t seem to be any logic. Sometimes it renders without a problem and sometimes not. if it cannot render then i cannot make an avi file either.
    Any ideas how to solve this problem??
    Need help URGENTLY!!!
    Ann Bens replied 15 years, 4 months ago 2 Members · 3 Replies
  • Ann Bens
    May 8, 2011 at 10:52 am
    When was the last time you did a clean install?
  • Ruth Geva
    May 8, 2011 at 3:34 pm
    My computer is used only for editing movies. I don’t have on it anything except the movie I am working on – and not even the original avi or jpg files are there, but on an external hard disc.
    However, since i wrote, i think i have solved the problem, at least partially. The trick is to render only parts of the sequence every time – marking the unrendered part as the work area – and then the render is done on only a small segment of the sequence at a time. |This seems to work, meanwhile… it must be some kind of bug in the software.
  • Ann Bens
    May 8, 2011 at 6:39 pm
    There is no bug in the software.
    Using a external HDD can cause problems. Move the files to an internal drive and try again.
    A pc can go off after sometime even if its only used for video-editing. So ones in a while when things do not run very well a clean install is in order.
