Rendering Problems
I’m trying to render my video in HDV 720-30p (1280×720, 29.970 fps) but when I get to the “Render as” page and go to the drop down menu and try to select WMV the description box goes grey and reads “No existing templates support this media.” When I click custom and try to change the template when I fill all the boxes with stuff and click OK an error message pops up and reads “The custom template you selected is not valid with the current project settings. It has been filtered out of the template list.” And then the box goes grey again. Then when you attempt to click “save” it reads “There is not template available for this format” I have tried other versions of this program. It might be the Codac’s, not exactly sure. I have the K-lite Codec Pack (full) and Microsoft’s .net 1.1,2.0,3.0,3.5 and 3.5 Compact. I searsolly need help so anything would be great, thanks in advance!!
