Activity Forums VEGAS Pro Rendering problems
  • Rendering problems
    Posted by Trey Isbell on June 9, 2008 at 1:33 pm
    When I go to render my video I get an error memory to low. I checked the memory and I am only using 64% of my physical memory. Anybody have this problem before.
    Trey Isbell replied 18 years, 3 months ago 2 Members · 4 Replies
  • Mike Kujbida
    June 9, 2008 at 2:04 pm
    Trey, I can’t help but notice that you’ve asked several questions since you started posting here without too many solutions offered.
    What would help us to help you is for you to give us a list of your system components.
    Version of Vegas used;
    CPU speed;
    Operating system;
    Amount of RAM;
    Number & size of hard drives;
    Video format(s) that you edit with;
    List of other relevant programs used (Photoshop, After Effects, etc.);
    Brand of anti-virus software.
  • Trey Isbell
    June 9, 2008 at 2:26 pm
    SONY VEGAS PRO 8.0B
    WINDOWS VISTA
    AMD 64 X2 DUAL CORE 5000+ 2.6GHZ
    3GB RAM
    32 BIT OPERATING SYSTEM
    NORTON ANTIVIRUS
    1 500 GB HARD DRIVE
    I DONT USE ANY OTHER PROGRAMS WITH VEGAS
    VIDEO FORMATS SOME MPEG2 FROM SONY HANDYCAM
    SOME AVI FROM HELMET CAM
    THE FIRST PROBLEM I HAD WAS AN ERROR DURING THE EDITING PROCESS IT SAID EXCEPTION OCCURED AND WOULD SHUT DOWN. I STARTED ANOTHER PROJECT WITH THE SAME FILM AND NOW I GET AN ERROR MEMORY IS TO LOW WHEN I TRY TO RENDER SO I CAN BURN TO DVD.
  • Mike Kujbida
    June 9, 2008 at 4:03 pm
    SONY VEGAS PRO 8.0B
    WINDOWS VISTA
    3GB RAM
    So far, so good.
    NORTON ANTIVIRUS
    Uh oh.
    Norton AV is known to be a real resource/memory hog.
    At the very least, disable it during any renders.
    If at all possible, replace it with something far less obtrusive like PC-Cillin or Kaspersky.
    1 500 GB HARD DRIVE
    Hard drives are very cheap these days.
    Do yourself a favour and get at least one more, preferably two.
    Use drive C for your apps and drive D for any & all material related to video production.
    Change all relevant folder locations (temp, render, etc.) in Vgeas so that they point to drive D and not C.
    MPEG-2 footage from miniDVD camcorders have been know to cause problems, even with reasonably powerful systems like yours.
    Is it DV-AVI or someting like DviX or Xvid?
    My last suggestion is to make sure you’re not connected to the ‘net while doing any video editing.
  • Trey Isbell
    June 9, 2008 at 6:22 pm
    Thanks for your help I will try and sort out the problem.
