Activity › Forums › VEGAS Pro › Rendering problems
  • Rendering problems
    Posted by Gerge211 on June 5, 2007 at 2:21 am
    Can someone HELP??? I’ve been having trouble with rendering vegas. I have spent about 3 hours on the phone with vegas tech support so I have tried alot of different things. Uninstall, reinstall, shut down backround processes, pretty much everything you can do, and I still get the same problems. Sometimes I get a hard shut down of the entire cpu, or I will get the error message UNKOWN ERROR has occured. Then more recently I have been getting the error listed below. I have also been getting a message when I turn vegas on saying ” Themssql$sony_med1amgr service does not exist or the current account does not have enough privalge to manage it.” I have a good computer so you think pentium 4 3.40ghz and 2 gigs of ram and an external hard drive with a lot of extra memory. So can anyone help !!!!
    this is the error I mentioned earlier.
    Sony Vegas 7.0
    Version 7.0c (Build 169)
    Exception 0xC0000005 (access violation) READ:0x70007900 IP:0x70007900
    In Module ‘vegas70.exe’ at Address 0x0 + 0x70007900
    Thread: ProgMan ID=0xFC Stack=0x1B4F000-0x1B50000
    Registers:
    EAX=70007900 CS=001b EIP=70007900 EFLGS=00010202
    EBX=02279ce8 SS=0023 ESP=01b4f874 EBP=00000001
    ECX=009affff DS=0023 ESI=0da184d0 FS=003b
    EDX=0daabef0 ES=0023 EDI=00237350 GS=0000
    Bytes at CS:EIP:
    70007900: .. .. .. .. .. .. .. .. ……..
    70007908: .. .. .. .. .. .. .. .. ……..
    Stack Dump:
    01B4F874: 006A0043 00400000 + 2A0043 (vegas70.exe)
    01B4F878: 0DB2E870 0D760000 + 3CE870
    01B4F87C: 0DAABEF0 0D760000 + 34BEF0
    01B4F880: 0023AD80 00140000 + FAD80
    01B4F884: 0DAABEF0 0D760000 + 34BEF0
    01B4F888: 00000000
    01B4F88C: 8004E00A
    01B4F890: 00000185
    01B4F894: 00000005
    01B4F898: 00000004
    01B4F89C: 00000000
    01B4F8A0: 0023735C 00140000 + F735C
    01B4F8A4: 0069E4AE 00400000 + 29E4AE (vegas70.exe)
    01B4F8A8: 0DAABEF0 0D760000 + 34BEF0
    01B4F8AC: 01B4F8C0 01A50000 + FF8C0
    01B4F8B0: 0D8C5E80 0D760000 + 165E80
    > 01B4F8C4: 006A6135 00400000 + 2A6135 (vegas70.exe)
    01B4F8C8: 0DAABEF0 0D760000 + 34BEF0
    01B4F8CC: 01B4F924 01A50000 + FF924
    01B4F8D0: 0000257C
    01B4F8D4: 021C2FEC 02130000 + 92FEC
    > 01B4F8F8: 004E236F 00400000 + E236F (vegas70.exe)
    01B4F8FC: 0000257C
    01B4F900: 00000000
    01B4F904: 0000257C
    01B4F908: 00000000
    > 01B4F950: 004E236F 00400000 + E236F (vegas70.exe)
    01B4F954: 0000257C
    01B4F958: 00000000
    > 01B4F95C: 004E24F7 00400000 + E24F7 (vegas70.exe)
    01B4FFF0: 00000000
    01B4FFF4: 005198A0 00400000 + 1198A0 (vegas70.exe)
    01B4FFF8: 00A82370 00400000 + 682370 (vegas70.exe)
    01B4FFFC: 00000000
    Gerge211 replied 19 years, 3 months ago 3 Members · 5 Replies
  • Gary Kleiner
    June 5, 2007 at 2:49 am
    Heat problem?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Gerge211
    June 5, 2007 at 3:58 am
    Maybe? If that is the problem what can I do?
  • Gary Kleiner
    June 5, 2007 at 4:47 am
    Better/more ventilation.
    Lower ambient temperature.
    Gary Kleiner
  • Doug Graham
    June 5, 2007 at 12:26 pm
    The Media Manager problem is, I think, related to the version you are using (7.0c). 7.0d is available for download and fixes a number of bugs. 7.0e is also available, but I’ve heard some folks are having problems with it.
    The halts while rendering might indeed be heat-related. If you have a little utility that can report the CPU and motherboard temperatures, run it while you’re rendering. If the temps go up to 60 C or more, you should think about getting more or better cooling fans. Also, if you haven’t blown the dust out of your machine in a while, do so.
    Are you using an external drive as a video source or render destination? USB or Firewire interfaces can present a data bottleneck and a crash. Your drives, whether internal or external, should use SATA or SCSI interfaces.
    Is your machine optimized for video editing? Running a lot of processes or background applications can use up resources. There’s a couple of good articles on Windows tweaks and streamlining available through Gary Bettan’s site, https://www.videoguys.com
    Regards,
    Doug Graham
  • Gerge211
    June 19, 2007 at 1:44 am
    Well, still having the same problems. I have noticed another bizarre thing. When I render a video in quicktime the file size is huge. A 20 sec clip will be like 1 gig. A 42 sec file rendered as a windows media file is like 14.5 mb. This might be my problem. How do I compress them down without losing quality. I should be able to render in the highest setting without having such huge file sizes correct?
