Activity Forums VEGAS Pro Rendering problems
  • Rendering problems
    Posted by Yahoodood on June 11, 2006 at 6:54 am
    I’ve been using vegas for a while, and just recently i’ve been having major rending problems with VEGAS 6.0.
    When attempting to render in any video format, vegas WILL freeze around 89% or 90, depending on the format.
    I really need this project to render because it a school video project, and kind of panicing because this is due Monday. yay procrastination (not).
    I’ve tried reinstalling this, but nothing really works.
    Is there any solution to this?
    Thank you in advance
    -Dennis
    Dan Sherman replied 20 years, 3 months ago 4 Members · 5 Replies
  • Dror
    June 11, 2006 at 4:48 pm
    It happened to me last night. Ether it will freeze or it will complete rendering in 20 min instead 3 hours but when try to open the video it will not work.
    What I did was hard drive defragmenter . Then I rendered small part of the project for testing and it works.
  • Gary Kleiner
    June 11, 2006 at 6:59 pm
    Try rendering to a different drive if you have one.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Yahoodood
    June 11, 2006 at 9:55 pm
    Thank you both for your suggestions. I tried both, but in the end it ended up being corrupt 20 frames of video, that completely froze up vegas and the such. Unfortunately I had to delete these frames, but luckily was not too signifigant.
    Once again, thank you for your suggestions and help.
    -Dennis
  • Dan Sherman
    June 12, 2006 at 12:26 pm
    How did you discover frames were corrupt?
  • Dan Sherman
    June 12, 2006 at 12:28 pm
    Gary,—when you say render to a different drive.
    My project is on a swappable drive.
    So I should drag it onto another drive and re-render?
