Activity Forums Apple Final Cut Pro Legacy Rendering problems
  • Rendering problems
    Posted by Fredericknz on June 28, 2005 at 3:10 am
    Hi all, got a bit of a problem with a G5 iMac 1.8GHZ, 768MB SDram, 160Gb HD.
    In a project we are editing, when we go to render the render status bar flashes up and nothing happens. Under render all, render selection, render both etc the same thing happens, any help, suggestions etc gratefully recieved.
    FrederickNZ
    Fredericknz replied 21 years, 3 months ago 3 Members · 3 Replies
  • Craig Hotti
    June 28, 2005 at 1:15 pm
    Just stating the obvious because I miss stuff like this all the time:
    Make sure you are clicked on the timeline before hitting render.
    Trash preferences and reboot, might fix it.
    Hope it helps
  • Kevin Monahan
    June 28, 2005 at 7:18 pm
    Check the dark green FULL bar and the RED render bar in the Sequence>Render menus. This gets by everyone at least once.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Fredericknz
    June 28, 2005 at 8:53 pm
    Many thanks guys, I was doing things right, but trashed the preferences and hey ho! rendering returns!
    I haven’t had to trash preferences since OS9!
    Once again you guys rock!
    FrederickNZ
