Activity › Forums › VEGAS Pro › Rendering problem
  • George Dean
    June 15, 2019 at 10:56 pm
    Mos,
    Some of my suggestions. Use the free app Mediainfo to check the spec’s of your captured video. It will probablt say it is variable frame rate. Use the free app Handbrake to convert your captured variable frame source media to constant frame rate.
    Then use match media in project settings to match the converted file which should then be something like 1920×1080 FHD, 60 fps (59.940 fps), progressive. Use a matching render template from the Magix AVC or Sony Avc render formats (do not use video for window wmv render format).
    See if this gives you some better results.
    Best Regards……George
