rendering problem
I have a problem with rendering.
I put an 8 second clip in the timeline then I set the loop region to 8 seconds, then I click render as, and make sure the loop region only box is checked and I click save, for some reason it ignores the loop region and keeps rendering endlessly, it renders way beyond the loop region, I tried toggling the check box and rendering off and on but it keeps doing it
thanks
