Activity Forums VEGAS Pro Rendering problem
  • Rendering problem
    Posted by Anthony James on September 13, 2011 at 3:22 pm
    I’m using Vegas Pro 9.0. Today, I created a project that took me hours to do. However, I ran into a roadblock when trying to render.
    Originally I thought I was using files that Vegas simply didn’t like to render, which may or may not still be the case. I’m able to render each video file (there are multiple) on its own. The videos play just fine in the editing window and can be edited just fine.
    The problem is when I try to render them all together, most of them with the Track Motion function to sort of ‘split’ the screen between the multiple videos. The rendering process will hang at 0%, while the ‘rendering time’ and ‘time to complete’ continue to go up. The video render preview also does not move from the first frame.
    This causes Vegas to error. When I click Cancel, it does not actually cancel the render, it just stays on “Render canceled by user.” I then have to use the task manager to kill the process.
    I really don’t want to have to re-do all that work, and I’m really running out of ideas, which included re-converting the files to different file types and replacing them in the project, downloading ffdshow, moving the files to new video tracks and deleting specific videos to try to narrow down the problem. Is there perhaps some video decoder I have to download for Vegas?
    Any help is appreciated. Thanks!
    Anthony James replied 15 years ago 2 Members · 2 Replies
  • Tyson Onaga
    September 13, 2011 at 6:54 pm
    How many tracks to you have? You could try:
    a. render Track 1 to QuickTime Animation
    b. render Track 2 to QuickTime Animation
    c. create new project with matching properties
    d. insert renderA to Track 1; turn on Alpha channel
    e. insert renderB to Track 2; turn on Alpha channel
    f. render to your desired target
    Expand process for additional tracks.
    g. delete those pesky little .mov files when you’re done
  • Anthony James
    September 14, 2011 at 7:55 pm
    Err, well I found out the problem and I was wondering if you’d be able to explain this to me because it’s ridiculous.
    The problem wasn’t the wrong filetype, the number of video clips I had, the Track Motion function, how I edited the clips or even having the wrong codec.
    The problem WAS when I lowered any of the clips volume bars to “-Inf.” it errored and would not save. This was remedied by either increasing the volume to anything higher than “-Inf.” or setting the volume properties to “Mute.”
    I tried everything I could possibly think of to fix this and I was honestly about to give up, when, by process of elimination, I said “maybe it doesn’t like being on mute” and voila, the rendering process began.
    So why is this simple problem a huge mystery and hindrance? Thanks again for trying to help.
