Activity Forums Adobe After Effects Rendering problem
  • Rendering problem
    Posted by Adam Mcewen on June 7, 2007 at 7:39 pm
    Hi all,
    I am trying to render out an uncompressed quicktime version of a project with no sound. The render gets to a certain point and then fails with this error message.
    After Effects error: Adding to movie — Disk error (I/O error; bad media)(-36) (44::39)
    Anybody any ideas what this means?
    Syfromla replied 19 years, 2 months ago 3 Members · 3 Replies
  • Steve Roberts
    June 7, 2007 at 9:14 pm
    Have you run out of disk space?
    Have you defragged lately?
  • Syfromla
    June 18, 2007 at 5:04 am
    Hey Adam, I am experiencing the exact same problem/identical error message and wonder if you ever discovered a solution? A reply from you would be much appreciated. Thanks!
  • Syfromla
    June 18, 2007 at 10:26 pm
    Yo adam, I just found the solution and wanted to pass it on to you. Problem is how the harddrive is formatted. I had mine formatted to fat32 to work on both mac and pc, but fat32 has a 4gb limit, hence the cutoff/error message.
    Solution is working off a drive formatted HFS for mac (no 4gb limit)and using a software utility called Macdrive on the pc to read/write.
    Hope this helps you out too!
