Rendering problem
Posted by Sam Rose on March 9, 2007 at 9:39 pmHi
I have 7 minutes of footage. I have tried rendering it as PAL DV and uncompressed but it only renders about 30 seconds then it says it’s 100% and complete. What can I do I need this movie done for Sunday?Sam Rose replied 19 years, 5 months ago 2 Members · 5 Replies -
Sam Rose
March 9, 2007 at 10:07 pmHi
Another problem. I seemed to of solved that but the audio is now out of sync from the audio on the final render also there is a few scenes that have a black border and others don’t. How do I sort that? -
Don Bloom
March 9, 2007 at 10:19 pmClean it off and re-render the project-sounds like there might be something else running on your machine-anti virus program or something that’s throwing off the machine.
Don
Sam Rose
March 10, 2007 at 10:10 amIt seems the audio plays at normal speed but the video looks like it is in slow motion and that must be why it is out of sync. Why is the video slow?
Don Bloom
March 10, 2007 at 1:04 pmWithout knowing the settings you are using to render it would be impossible to even try to guess. Please give us some additional information so we can try to help you.
Are you rendering straight from the project timeline to MPEG-if so, what template are you using, what settings etc.
Don -
Sam Rose
March 11, 2007 at 2:27 pmHi
I had the rendering set to Full frames (uncompressed( and on best quality. I changed it to PAL DV and to good quality and it worked. Thanks for your help.
