Activity Forums Apple Final Cut Pro Legacy rendering problem
  • rendering problem
    Posted by Mfassett on June 29, 2006 at 12:20 am
    I’ve got the latest FCP, running on a dual 2.0ghz G5.
    For some reason, rendering a sequence is just stopping randomly, without any error message. I have autorender set to 1 minute, and even autorendering won’t get through a sequence.
    I tried various codecs, including mjpeg, sheer, ensharpen (screen shot based), and none will get through it. Any ideas? Thanks!
    Chris Poisson replied 20 years, 2 months ago 3 Members · 2 Replies
  • Kevin Monahan
    June 29, 2006 at 9:12 am
    try tossing prefs. then get back to us.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Chris Poisson
    June 29, 2006 at 1:28 pm
    Tossing prefs may work, but if it doesn’t then you likely have a corrupt clip or project. If it’s the first, the way to find out is go through the timeline and select the clips one at a time. Hit command r to render only that clip. keep going till you find the bad one(s). If it’s a bad project, make a new one and copy and paste everything in your browser and timeline into it.
    I have had this problem twice and the first solution worked both times.
    Have a wonderful day.
