Activity › Forums › Apple Final Cut Pro Legacy › Rendering Problem
  • Rendering Problem
    Posted by Solid Porcupine on February 22, 2006 at 6:15 am
    I have this wacky rendering problem.
    I’ve just upgraded to FCP 5 and when re-rendering some of my files the rendering finishes…
    yet the red, ‘needs rendered’ bar still appears there. When I select a portion of the sequence SOMETIMES it renders…I play with selecting
    different portions and after much frustration I can usually render the sequence completely. I’ve had this exact problem running Premiere Pro a few years ago and using Magic Bullet in older versions of FCP.
    Is there a simple answer…or complicated?
    This madness must end.
    SP
    Solid Porcupine replied 20 years, 7 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    February 22, 2006 at 12:40 pm
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Solid Porcupine
    February 23, 2006 at 7:27 pm
    Awesome,
    Thanks for all the information.
    SP.
