Activity › Forums › Apple Final Cut Pro Legacy › Rendering-pro res sequences
  • Rendering-pro res sequences
    Posted by Mike Varga on June 2, 2009 at 3:25 pm
    Hello,
    Hopefully there may be some light you could share here.
    Here’s my breakdown….
    I have 3 separate projects with 3 separate sequences- all Apple Pro Res 422. All 3 have been effected and fully rendered.
    I made a new project, and a new sequence (pro res).
    Now i went into each of the 3 old projects and highlighted the sequences, then command c and then command v into the new project sequence.
    Problem is all the media is now unrendered. Since i used a lot of heavy effecting my render time on my new sequence is about 9 hours for 20 min worth of material.
    Is there any way i can get the old sequences into a new sequence and avoid all of this rendering? Am I missing something?
    I also tried copying 2 of the old sequences (that were rendered) into the 3rd old sequence (rendered) and they still came up with the dreaded red bar.
    I can’t seem to figure this out.
    Thanks for all the advice in advance.
    Best,
    Mike V
    John Pale replied 17 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 2, 2009 at 6:43 pm
    Try duplicating the sequence that’s rendered…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • John Pale
    June 2, 2009 at 7:03 pm
    Check the field order in all the sequences.
