Activity Forums Adobe After Effects Rendering please help
  • Rendering please help
    Posted by Spikeyjohn on May 9, 2007 at 9:36 pm
    My big problem is that I made a promo video in DV Pal widescreen but when I export it(fps is 25 in both, double checked) the export video skipped like every 5 seconds or so but when I put it back and play it from AE its fine and smooth..is it my resolution thats making it happen like that? HELP SOS i have to hand it in by next tuesday
    Also when i export in quicktime, I cant remember the original settings so when i put it as quicktime video/full resolution/dv pal widescreen(or any other format) the rendered video is in a really bad quality..is my settings wrong?
    Thank
    John
    Mike Procunier replied 19 years, 4 months ago 2 Members · 3 Replies
  • Spikeyjohn
    May 9, 2007 at 9:40 pm
    ohh i forgot to mention my original rendering file is AVI
  • Mike Procunier
    May 10, 2007 at 1:56 pm
    How big is your final render? If it plays ok in AE but stutters in your media player, it probably that your computer can’t handle an uncompressed or high data rate file. That’s OK just make a compressed version for previewing/distribution etc.
  • Mike Procunier
    May 10, 2007 at 2:01 pm
    Are you exporting or rendering using the Make Movie command? If you use Make Movie (Command-M) you’ll have more output choices, can set up multiple renders at once and won’t forget which settings you used, because you’ll see all of your past renders and settings in the queue.
