Activity › Forums › VEGAS Pro › Rendering pictures
  • Rendering pictures
    Posted by Bob Yantorno on March 23, 2008 at 11:07 am
    Hi –
    I am using Vegas Platinum 8 and I have a picture of a mountain I have put in the video and lengthened the time it is displayed. When I render it and then go to DVD Architecture and put the lengthened clip in the menu the edges of the mountain have steps on it – there are no steps on the mountain. It’s as though the edges have a different resolution from the rest of the picture.
    Any help would be greatly appreciated.
    Thanks in advance for any help.
    Bob
    Mike Kujbida replied 18 years, 6 months ago 3 Members · 4 Replies
  • Mike Kujbida
    March 23, 2008 at 4:18 pm
    Here’s a few things to try, all within Vegas.
    If the image is large in (pixel) size, reduce it to project size.
    Use “Reduce Interlace Flicker” on the image.
    Apply a very light Gaussian blur (vertical only – set to 0.001) to it.
  • Bob Yantorno
    March 24, 2008 at 11:03 am
    Hi Mike –
    Thanks will try it. But still curious why it does it. Especially since the picture looks fine in Vegas but changes once it is rendered and then put in the menu of DVD Architecture.
    Also, I have noticed that there is some shimmering – with the rendered video – with lines and lettering – like rolling credits. How do I get rid of the shimmering? Might that be associated with the same problem with the staircase edged problem?
    Again – thanks –
    Bob
  • Adam Rose esq.
    March 24, 2008 at 12:52 pm
    if the text / lines are not broadcast safe, they can do that when viewed on a TV
    make sure white and black are set to 235,235,235 and 16,16,16 in your RGB values, rather than 255,255,255 and 0,0,0.
    or just apply a broadcast clamp to the output as a whole, though the normal video might not need it.
  • Mike Kujbida
    March 24, 2008 at 2:03 pm
    In addition to Adam’s broadcast safe colour recommendations, make sure you ‘re not using very fine text.
    Great Titles with the DV Codec is an excellent article about pitfalls to avoid when creating text for video.
