Activity › Forums › Apple Final Cut Pro Legacy › Rendering over and over
Posted by Brad Mirman on April 25, 2010 at 7:26 amI posted this a while back but didn’t get an answer. If I keep adjusting a clip and rendering it over and over does it degrade the image quality?
Brad
Brad Mirman replied 16 years, 5 months ago 3 Members · 5 Replies -
Rafael Amador
April 25, 2010 at 8:46 amI’ve answered once to your question that: unless you render to a 444 Uncompressed format there is always degradation.
rafael -
Tom Wolsky
April 25, 2010 at 9:59 amIf you are talking about repeatedly rendering the same clip in the timeline after you make changes, then no re-rendering has no effect. FCP renders from the original media file through all property changes from the top down. Each one is a new render from scratch.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Brad Mirman
April 25, 2010 at 4:53 pmhanks Tom. That’s what I wanted to know. I have a sequence that I have been working with in Magic Bullet Looks and have rendered some shots several time. I just wanted to make sure that I wasn’t making it worse by doing it so many times
Since each render is new, would it be a good idea to find all those previous rendered files and delete them to free up drive space?
Brad
Tom Wolsky
April 25, 2010 at 6:23 pmNo. FCP will dump the render files that are no longer needed for playback as long as they’re out of the undo queue or you close the application.
All the best,
Tom
