rendering out to play on plasma monitor
Hi there,
I have just completed a project that consist of all photograph stills. I panned them from right to left on the screen. The project needs to be completed on to a dvd so it can play on a Plasma monitor.
the clip was made in AE with a 720×480 widescreen pixel (1.2).At first attempt to render out the clip the movement of the stills on screen looked jittery and jumpy. However I managed to to fix that with rendering the clip with lower fields.
This made my DVD of the clip look smooth on a regular NTSC television monitor. Now to the problem: the clip played off the DVD still looks jittery and has horizontal lines showing, on the plasma monitor. It is also very jumpy and jittery played on computer monitor,off the DVD.
Any Ideas on how to render it out correctly and compress it correctly on to a dvd, so it will play smoothly on a 16:9 plasma monitor?
Thanks again
Rom
