Activity › Forums › VEGAS Pro › Rendering out of sync
  • Rendering out of sync
    Posted by Mbeg on November 8, 2005 at 2:52 am
    I did a wedding video where there is a segment where the flash from the photographers camera is causing some bad flickering in the finished render as viewed on a television. I removed the frames where the flash occurred and rerendered it. However, although the flash is not seen when I preview the clip before I render, it reappears on the rendered clip. I have tried multiple times and even removed a couple more frames before and after the frames where the flash is located. It seems that there is a slight sync problem at the frame level. Is this correct or is there a setting that can make the render more exact. I am using Vegas 5.0 with the latest update.
    Gary Kleiner replied 20 years, 10 months ago 2 Members · 1 Reply
  • Gary Kleiner
    November 8, 2005 at 3:32 am
    Make sure you are in Quantize to Frames mode and also compensate for whatever you do with the video in the audio as well.
    Gary
