Activity › Forums › Adobe After Effects › rendering out of CS3 with Prores 422?
  • rendering out of CS3 with Prores 422?
    Posted by Paul Nevison on November 29, 2007 at 2:21 am
    hey so
    is prores 422 working as an option to render out of AE CS3? I did a search and saw that there was an issue with importing prores into AE, are there any known issues with rendering out to that codec?
    it’s a significant space saver over animation and wondered if people are using it successfully.
    thanks
    Macpro 2x 3Ghz
    4.0G RAM
    OS 10.4.10
    QT 7.2
    FCP 6.0.1
    AE CS3
    BMD Decklink HD Extreme 6.6
    PAL Land
    Jeremy Garchow replied 18 years, 10 months ago 4 Members · 17 Replies
  • 17 Replies
  • Jeremy Garchow
    November 29, 2007 at 5:36 am
    I just started a thread earlier today.
    It was working very well for me today after I figured out how to render out to trillions:
    https://forums.creativecow.net/thread/2/922047
    Not only is it a space saver, but it’s 10bit as opposed to Animation’s 8bit.
  • Paul Nevison
    November 29, 2007 at 6:35 am
    hey Jeremy,
    read the thread and repeated what you did and I can’t get prores to render in trillions. just to make sure are you selecting trillions in the output module dialog?
    thanks
    Macpro 2x 3Ghz
    4.0G RAM
    OS 10.4.10
    QT 7.2
    FCP 6.0.1
    AE CS3
    PAL Land
  • Jeremy Garchow
    November 29, 2007 at 6:58 am
    Yes, are you on AE 8.0.1?
    And you trashed your preferences?
  • Paul Nevison
    November 29, 2007 at 11:26 am
    yes 8.0.1 and i trashed prefs….the trillions option is still greyed out
    Macpro Duel core 3Ghz
    4.0G RAM
    OS 10.4.10
    QT 7.2
    FCP 6.0.1
    AE CS3
    PAL Land
  • Jeremy Garchow
    November 29, 2007 at 4:11 pm
    That’s weird man. I just did it on my laptop last night to make sure. After I trashed preferences (and emptied the trash) @ User > library > Preferences > Adobe > After Effects > 8.0 > Adobe After Effects 8.0 Prefs the trillions option shows up in AE. AE must be quit when you trash your prefs.
    Jeremy
  • Jeremy Garchow
    November 29, 2007 at 6:00 pm
    You ‘can’t’ get ProRes without FCP.
    That’s a good call, though, even if you have the codec without FCP.
    I can check that and get back.
    Jeremy
  • Jeremy Garchow
    November 29, 2007 at 6:03 pm
    Just checked, and no you don’t need FC installed.
    Jeremy
  • Paul Nevison
    November 30, 2007 at 1:19 am
    hey jeremy,
    yes trashed those prefs in the path you supplied, restarted and still in the output module in render que tab/video output/ depth drop down menu….the only choice i have is millions.
    I have FCP 6.0.1 installed.
    It’s very strange that we are seeing different results….there is something I am obviously not doing correctly.
    4.0G RAM
    OS 10.4.10
    QT 7.2
    FCP 6.0.1
    AE CS3
    PAL Land
  • Jeremy Garchow
    November 30, 2007 at 5:15 pm
    Another good call. I am on the most up to date Tiger/Quicktime/FCP there is (all the updates were posted about two weeks ago) FCP 6.0.2, QT 7.3, OS 10.4.11. On a side note, FCP is much more stable @ 6.0.2 than 6.0.1 and I haven’t seen any issues with QT7.3. Personally, i think the upgrade is worth it as long as your capture card drivers can support the latest update, but I can understand if you don’t want to update.
    Jeremy
  • Paul Nevison
    November 30, 2007 at 9:07 pm
    That could be it I guess. I’m in the middle of a big project so can’t afford a major upgrade.
    would be good to find out if your process can be repeated on a FCP 6.0.1/7.2 system.
    4.0G RAM
    OS 10.4.10
    QT 7.2
    FCP 6.0.1
    AE CS3
    PAL Land
