Activity Forums Zaxwerks rendering orthographic view
  • rendering orthographic view
    Posted by Sney Noorani on October 12, 2008 at 7:58 pm
    is it possible to render the orthographic view to the comp in ProAnimator?
    I’m a noob to it, so I may not know the obvious, i’ve got as far as importing my object, beveling, texturing, and now I just want an orthographic still…
    every time I select render to comp, the image has perspective, but I want it to look beveled, textured, but ‘flat’.
    thanks in advance
    Sney //
    Jon Okerstrom replied 17 years, 11 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    October 16, 2008 at 1:04 am
    Hi Sney,
    You’ve hit on something that strikes me as odd, too. You can render to orthographic when PA is running as a standalone but the behavior isn’t the same when you use PA as a plug-in for After Effects.
    I’m not sure why, but I’ll noodle it for a while. I also suspect Zax or Matt will fill us in.
    Jon
