Activity Forums VEGAS Pro rendering options after editing 7D HD footage
  • rendering options after editing 7D HD footage
    Posted by Paul Clark on July 13, 2010 at 11:39 pm
    hey,
    hope this is in the right place, apologies if not.
    Basically i am in the middle of making an indy snowboard movie shot completely on a canon 7D and to be put on a dvd at the end. i need the final video to be as high a quality as possible to show the HD qualities of the 7D. film is going to be approx 30 mins long
    When dropping the footage (.mov) straight into vegas (pro 8) i found it staggered quite a bit in the preview so have been rendering as an uncompressed .avi and editing from that. the file size is huge but it overcomes the problems. firstly does anyone know if this is an approved way of doing this without losing too much quality? or is there a more effective way?
    secondly, i would love some advice on the best rendering settings to use. some of the footage is shot at 720p PAL 50fps and some shot at 720p PAL 25fps. at first i was rendering as ‘HDV 720-25p intermediate’ and VLC player would only play sound. so messed around with other options but most wont play through VLC. If i render as an uncompressed avi then the playback staggers as the file size is so huge and has to buffer.
    i have since been rendering as WMV at ‘5mbps hd720-25p video’ but feel like i have lost more quality than i want.
    any advice on the above and what rendering settings would be best for me would be massively appreciated.
    thanks
    paul
    Don Donatello replied 16 years, 1 month ago 3 Members · 4 Replies
  • Douglas Spotted eagle
    July 14, 2010 at 6:58 am
    Render to MPEG @ 8.5 Mbps if DVD is your destination
    Otherwise, render to MP4 @ 1280 x 720, 10Mbps if the web is your destination and you want little loss.
    Rendering to uncompressed works, but IMO, .mxf is better. You’re dealing with no chroma resampling, and Vegas loves .mxf. You’ll save a LOT of space and time, too
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Paul Clark
    July 14, 2010 at 7:58 am
    hey, thanks for the reply. the mxf idea works great, thanks for that. much cleaner and easier to work with now.
    as for the final rendering though, could you go into a little more detail about which is best to render as. there are so many sub options to each category. and i cant find an 8.5mbps option within the mpeg sectipon. im presuming its not the best idea to render as hdv? and do you know why vlc wont play any mpeg2 rendered files?
    cheers
    paul
  • Paul Clark
    July 14, 2010 at 8:25 am
    in fact, thinking about it, i could get away with re-rendering the file to mxf again??? for me its the best quality, low lagging output file ive tried. is it easy enough to get mxf files onto DVD?
    cheers
  • Don Donatello
    July 14, 2010 at 6:08 pm
    “i cant find an 8.5mbps option within the mpeg section”
    look in CUSTOM ..
    select constant bit rate and type in the 8,500,000 bit rate ..
