Activity Forums VEGAS Pro Rendering only one part
  • Rendering only one part
    Posted by Steve Edwards on July 27, 2009 at 11:43 pm
    I have a whole project ready to render, but right now I would like to just render the end of the project, meaning the credits only. How can I just render the credits now.
    Mike Kujbida replied 17 years, 2 months ago 2 Members · 5 Replies
  • Mike Kujbida
    July 28, 2009 at 12:35 am
    Highlight just that section and make sure to select “render loop region only”.
  • Steve Edwards
    July 28, 2009 at 1:05 am
    Thanks Mike, and to cancel that loop region I have to do what?
  • Steve Edwards
    July 28, 2009 at 1:12 am
    Oh, other question was should I render to avi or mpeg2. I thought that I read somewhere that if you re-render mpeg2 a second time you may lose some quality. Once project is done, I will put into Adobe Encore DVD. So when I render project, should I save as avi, and let Encore encode the project, or go ahead and render as mpeg2 anyway. I usually go ahead and render in mpeg2, then load into Encore.
  • Mike Kujbida
    July 28, 2009 at 2:32 am
    Just make sure not to select “render loop region only” the next time you render.
    This feature can be turned off if you want to.
    Options – Prefs – Editing – deselect “Collapse loop region when no time selection is present”.
  • Mike Kujbida
    July 28, 2009 at 2:36 am
    Steve, I use DVD Architect to do all my DVD Authoring and I always give it fully compliant MPEG-2 and AC-3 streams.
    I have no idea what the requirements are for Encore so I won’t bother suggesting something that might be incorrect.
