Activity Forums Adobe After Effects Rendering NTSC HD as PAL
  • Rendering NTSC HD as PAL
    Posted by Dan Brazil on January 9, 2012 at 8:04 pm
    Hello,
    I am working on a project for a large video wall in NTSC 29.97 fps Progressive with a canvas of 4092×1188. I had a clutch of video sources and I plumbed for 29.97 based on majority wins plus I wanted to achieve a smooth scroll of background animation.
    Anyway I probably digress…I understand that to avoid Judder the playback device video card and refresh rate of the LCD/Plasma screens need to be taken into account. So I want/need to deliver a version of my file in PAL 25 fps and I am trying to work out the best approach. Trying to keep it simple…so will it suffice to simply change the render output settings to PAL 25fps? I am importing my composition into Adobe Media Encoder and outputting an H264.
    If it helps, here are the words of wisdom from Scala – the software that will be running the show:
    https://www.scala.com/support/enterprise-scala/technical-faqs/scala-player-5-faq/video-quality-playback-suggestions-and-issues
    Any tips appreciated.
    Mac Pro, 2×2.26 GHz Quad Core Intel Xeon, 8GB RAM
    Dan Brazil replied 14 years, 7 months ago 2 Members · 2 Replies
