Activity Forums DaVinci Resolve rendering not adding grades
  • rendering not adding grades
    Posted by Keith Mottram on June 5, 2012 at 4:40 pm
    Okay, so I haven’t used davinci in a while, so i may be making a school boy error. what i want to do is add a basic grade and a lut to some alexa log footage and then render out prores422 for editing. I have added my footage, made a timeline, put the lut on, done a quick contrast/ colour grade. and then rendered. the problem is the render is coming out as source- no grade on (though burn ins are there and it is pr422 rather than 4444). am completely stumped restarted and started from scratch but to no avail. am getting a little bit desperate so all help is gratefully received.
    keith mottram
    spec davinci 8.2, mac pro 8 core, 10.7.3, gtx285, bm hdpro, + all the trimmings…
    Marc Wielage replied 10 years, 8 months ago 10 Members · 17 Replies
  • 17 Replies
  • Barrie Williams
    June 5, 2012 at 5:24 pm
    Double check up down arrow keys. They disable grades. But most likely on the render page, bottom left, make sure it’s not set to render source only.
    Barrie
  • Keith Mottram
    June 5, 2012 at 5:52 pm
    Hi Barrie,
    thanks for the reply. I cannot see a check box for render source only? The only source checkbox on the render page is the one above target.
    Also might be worth adding that when i hit render- the shot moving is the graded version. I am once again stuck.
    Keith
  • Robert Due
    June 5, 2012 at 5:53 pm
    do you have flat pass selected? that might be it?
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    DaVinci 8.2
    OSX 10.6.8
    MacPro 8-core 4,1 2.93 Ghz
    8GB RAM
    Nvidia GT120/GTX288 (CUDA 4.0.19)
    Decklink Extreme3D+
    Panny BT-LH1710P/ Panny BT-LH2600W
    Tangent Wave
  • Keith Mottram
    June 5, 2012 at 6:35 pm
    Hi Robert,
    have flat pass set to off.
  • Keith Mottram
    June 5, 2012 at 6:41 pm
    4242_screen.tiff.zip
    link to a screen grab of render page
  • Dwaine Maggart
    June 5, 2012 at 6:57 pm
    While you are rendering, do you see the expected grades in the Color page Viewer, as it’s rendering? If you do, then that MUST be in the rendered files. If you see the grades while rendering, but don’t see the grades in the rendered files, that would almost have to mean you are not really looking at the files Resolve just rendered.
    What type of system is this? What version of Resolve software? What type of GPU card do you have? If Mac, what version of OSX are you using?
    If you have OSX 10.7.4 and an ATI/AMD GPU, you MUST use the 8.2.1 beta 3 version of Resolve.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Keith Mottram
    June 5, 2012 at 11:37 pm
    Hi Duane, I am seeing the expected grades in the viewer as it is rendering. as mentioned before i can even render the burn ins. but the shots are gradeless. this is why i am confused!
    system is davinci 8.2, mac pro 8 core, 10.7.3, gtx285, bm hdpro, 12tb internal raid, etc
  • Dwaine Maggart
    June 5, 2012 at 11:57 pm
    To the best of my knowledge, what you are describing is not possible. What you see while rendering, is what’s being rendered. So I am also confused.
    If you can do an Export+ of your project (you can’t do this while it’s loaded) and send it to davincihelp (at) blackmagic-design.com, we can take a look at it and try to see if there is anything odd with the project settings.
    Dwaine Maggart
  • Keith Mottram
    June 6, 2012 at 12:07 am
    emailing now thanks.
  • Keith Mottram
    June 6, 2012 at 11:27 am
    It was user error, which Dwaine worked out when testing my project. had accidentally set the LUT to display rather than output.
    Dwaine you are as much a legend as I am an idiot!
