Activity › Forums › Apple Final Cut Pro Legacy › Rendering nonsense – surely this is not correct?
  • Rendering nonsense – surely this is not correct?
    Posted by Andrew Crow on August 20, 2009 at 7:13 pm
    I am tearing my hair out with FCP and it’s stupid rendering, although hopefully the problem is my ignorance of the program!
    I just changed the colour correction filter on a video track which is below another track and it apparently now needs to render the whole timeline! Hardly any of this video track is seen as there is a track above it.
    Is there some setting to stop this idiocy and extreme waste of time (4 hours to render nothing!)?
    Andrew Crow replied 17 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • David Roth weiss
    August 20, 2009 at 7:31 pm
    Andrew,
    If you give us more info we can probably tell you how to adjust your realtime settings so that you needn’t render before previewing after adding a color correction filter. However, since you’ve never posted here before and since we have no idea what hardware you have, what type of video you’re editing, whether you have a raid, or what version of FCP you’re running, we’d simply be guessing. So, if you help us to help you, we’ll happily provide the help you’re looking for.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Tom Matthies
    August 20, 2009 at 7:38 pm
    Use the razor blade to add cuts to the top track(s) over the clip you are changing. This way it will only need to render the small part you changed rather than the entire timeline.
    Tom
    Life moves pretty fast. If you don’t stop and look around once in a while, you could miss it.–Ferris Bueller
  • Andrew Crow
    August 20, 2009 at 7:54 pm
    Thanks for the quick replies. It was my intention to make the cuts on the top track, working my way down.
    I am editing a wedding which was filmed using 3 cameras. I have the static cam on the bottom track on the timeline, cam 2 above that and cam 1 on the top.
    I colour corrected cam 2, of which only a few seconds was actually displaying on the edit. Final Cut decided it needed to render the whole 30 minutes or so of video even though the only visible changes affected a few seconds of video.
    Alas, I do not have any raid drive setup yet – it’s just an external usb 7200rpm drive. I am editing on a MacBook Pro 2.6Ghz Duo, using FCP 6.0.4. The footage was HDV, captured as Apple ProRes.
    Hope this info helps but if you need any more let me know.
  • John Pale
    August 21, 2009 at 1:36 am
    Just use a variation of the blade technique that Tom suggested. Isolate the area that you are changing with the blade tool, then you only have to render what you changed.
    In the future you might want to make use of the multiclip feature instead of stacking all your cameras on different tracks. Much easier to work with, unless you stopped and started the camera a lot.
  • Andrew Crow
    August 21, 2009 at 10:19 am
    Thanks John,
    I was planning on doing exactly what you suggest, using the blade tool to cut out the bad shots on cam 1, revealing cam 2’s footage, and cutting out cam 2 to reveal the safe shot also. This is the way multicam editing has been done for a long time.
    I didn’t film the hymns (the safe camera picked up the audio in case that was needed) in order to minimise tape changes so there are a lot of stops and starts which makes the multicam editing a bit of a pain.
    To refine my question a bit further: is it normal for Final Cut Pro to immediately throw away all the render files when you make a change to a video clip which does not change the actual display output and if so why on earth does it do this whilst calling itself a professional product!?
    I have noticed that when I drag a clip roughly in place on the timeline it immediately junks all the render files where that clip has been placed and does not bring them back when it is moved. From memory other editing programs are a bit more flexible and keep the rendered video a bit longer.
    There is just no way I can take a 4 hour break and not use my editing system during that time just because I have colour corrected a clip that we will only see 1 minute of!
    I get what you are saying about cutting up the clips so only small parts need to be rendered but this is just a workaround for very poor software in my opinion. It’s a shame because I like FCP but I may have to start using Premiere CS4 if there is no way to cut down the pointless rendering times.
  • Tom Matthies
    August 21, 2009 at 9:19 pm
    As John notes above, it’s really not so much the software, it’s the way you are using it. If you are cutting multiple cameras, do use the multiclip feature. It will eliminate many of the problems you are experiencing. Also you state above that you are using USB drives for media? Another bad idea. USB drives generally don’t work well for editing. Use Firewire 400/800 or eSATA if you are on a budget. Dump the USB drives.
    Tom
  • Andrew Crow
    August 22, 2009 at 7:17 pm
    I did use the multicam mode a while back but found it quite awkward getting all the clips lined up properly. To be fair that was footage from a looping event which I filmed many times from different angles but I do remember having to do a lot of working out of where clips should go.
    Thanks for the reply – I have been using a usb drive, but have just set up a dual disk firewire 800 raid drive (which I was using for backup in raid 1!). Should have really thought of doing that before!!
    So am I correct in thinking that Final Cut is a bit thick when it comes to handling renders then? I mean if it renders video which is not even seen then that is a bit stupid!
  • Andrew Crow
    August 25, 2009 at 12:08 pm
    I found out what the problem was: Sequence settings were fine for the footage from my ‘B’ cam. (1920×1080), but obviously not for the other 2 cameras which were in HDV dimensions (1440×1080).
    Once I set the sequence properly there was much less rendering required. FCP also does not now render unseen video, which helps!
    Also got the firewire 800 drive set up to run faster with the 2 drives showing up as one (not mirroring as was before!).
