Activity Forums Adobe After Effects Rendering Non-Drop Frame from After Effects
  • Rendering Non-Drop Frame from After Effects
    Posted by Brandon Campbell on April 25, 2012 at 7:08 pm
    Wonder if anyone can help me with a timecode/frame rate question:
    I am rendering out animations from AE to be projected in a theater piece.
    The guy I’m delivering the files to is using Ki Pro (which I know nothing about) to run the movie clips to
    the projector. He is saying that he needs 29.97fps non-drop frame clips rather than drop frame.
    I see in my Project Settings that I can change the Display Style to Non-Drop Frame under the drop down
    menu for NTSC. I have that on Non-Drop Frame, still he is telling me the files I’m delivering are drop frame.
    My comp settings are HDV/HDTV 720 29.97, 1280×720, 29.97 fps.
    I’m in After Effects CS5, using Apple Pro Res 422 codec.
    Is there anything else I should be doing to make sure I am delivering non-drop frame clips?
    I’m not new to AE but have never had to deal with this before.
    B
    John Cuevas replied 14 years, 5 months ago 2 Members · 1 Reply
  • John Cuevas
    April 26, 2012 at 11:03 am
    Change your frame rate to 30FPS, that’s will change your frame rate to non-drop.
    I don’t know of system that would run a frame rate of 29.97 and be non-drop, that doesn’t make sense and I think the guy asking for the deliverable is confused.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
