Activity › Forums › VEGAS Pro › Rendering MXF audio issue with V9
  • Rendering MXF audio issue with V9
    Posted by Scott Moore on October 1, 2009 at 2:42 am
    I’m little new to Vegas. But I am having a strange problem rendering out to MXF format.
    I am working with an HD 720p timeline. I have a slate with sound, empty medium and then a spot with audio. I try to render to MXF HDD 1280X720p 60 29.93 50mp setting. Sometime it will render with just the slate with audio, but the spot does not. If I render again with no changes the slate will not have audio but the spot will. Then there is other time that nothing will work.
    I have the multichannel mapping checked and the channels 1, 2 turned on.
    Does anyone have any suggestions. I am having to render out to MXF to put on the XDCam Disk.
    Thanks for the help.
    Scott Moore replied 16 years, 11 months ago 2 Members · 3 Replies
  • Douglas Spotted eagle
    October 1, 2009 at 6:43 pm
    I haven’t done multi in 9 for XDCAM, but it should be the same as 8?
    I’ll connect my XDCAM and see what happens, this might be a bug not yet caught.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Scott Moore
    October 1, 2009 at 6:47 pm
    I heard your the best. I am rendering the file out using render as first before going to the eport video to XDCAM Disc option.
    Thanks again.
  • Scott Moore
    October 7, 2009 at 12:53 am
    Spotted Eagle,
    Were you able to get anywhere with the MXF render or a answer to my problem.
    Thanks.
