Activity Forums VEGAS Pro Rendering mpg2 w/o recompressing
  • Rendering mpg2 w/o recompressing
    Posted by Don Hutcheson on February 12, 2011 at 12:37 am
    I am copying an older project of mine that only exits on a DVD in mpg2. After importing into Vegas pro 9, how can I make a few simple cuts and get it back on DVD without recompressing and the resultant quality hit?
    Thank you,
    Don Hutcheson
    Randal Petryshyn replied 15 years, 7 months ago 3 Members · 2 Replies
  • Steve Rhoden
    February 12, 2011 at 3:19 am
    If its imported and on the timeline as mpeg2 format and you
    add just simple cuts and you render back out as the same mpeg2,
    then their will be no recompression…(only the edited/cut areas will be recompressed)
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
  • Randal Petryshyn
    February 12, 2011 at 5:51 am
    If you used CBR it can be done. You must set the CBR the same or higher than the original. If you used VBR you are out of luck.
