Activity Forums VEGAS Pro Rendering mpeg2 in Vegas vs. letting DVDA render it
  • Rendering mpeg2 in Vegas vs. letting DVDA render it
    Posted by Ken Wilson on May 12, 2006 at 5:44 pm
    So, is there any real difference between letting DVDA render your mpeg2 file from a DV-AVI, and rendering the mpeg2 file in Vegas? I’ve always rendered the mpeg2 with Vegas, but I’ve seen several posts on here suggesting that rendering through DVDA is better.
    Is there truly a difference?
    Ken Wilson replied 20 years, 4 months ago 3 Members · 3 Replies
  • Edward Troxel
    May 12, 2006 at 5:54 pm
    The both use the same rendering engine (it’s a shared component) so we can take that out of the equation. Now the question becomes why Vegas and not DVD A?
    1) Vegas allows you access to the various rendering parameters – DVD A does not. For example, you can manually specify the bitrate, choose CBR vs VBR and even 2-pass VBR. This cannot be changed in DVD A.
    2) In Vegas you would render to MPEG2 direct from the timeline without going through the DV-AVI intermediate. This will, theoretically, give you a better final result – especially with pictures, titles, and other generated media, because you will not be changing the color space multiple times.
    However, there’s advantages in letting DVD A handle everything as well:
    1) You don’t have to worry about setting the proper bitrate.
    2) You don’t have to render the audio separately.
    Edward Troxel
    JETDV Scripts
  • Timothy Duncan
    May 12, 2006 at 6:19 pm
    I think it is cleaner in DVDA. It takes longer, but is doing a better job at the variable encode according to my testing. You can definitely see the difference when you encode at lower data rates when trying to fill up a DVD.
    td
  • Ken Wilson
    May 12, 2006 at 8:44 pm
    Ed says:
    “However, there’s advantages in letting DVD A handle everything as well:
    1) You don’t have to worry about setting the proper bitrate.”
    This was pretty much the only advantage that I could see. Because I’ve been cutting DVDs longer than I’ve had Vegas and DVDA, I’m used to setting my own bitrates (especially for projects approaching the 2 hour mark), but I can see how the ‘fit to disc’ option in DVDA would be pretty appealing to those folk who don;t want to deal with it.
    Thanks for the responses!
