Activity Forums VEGAS Pro rendering MPEG
  • rendering MPEG
    Posted by Pieper1 on February 3, 2006 at 5:37 am
    i am rendering a finished dv project in vegas 6.0c.
    i am rendering it in MPEG-2 — “DVD Architect video stream”. i just wanted to know what is the difference between single pass and two pass MPEG besides the fact that rendering time is doubled?
    does it improve picture quality all?
    Peter Wright replied 20 years, 7 months ago 3 Members · 2 Replies
  • Gary Kleiner
    February 3, 2006 at 5:56 am
    It’s a more thorough analysis of how the compression is to be applied.
    I have not found it to make much of a difference (if any). However, results can vary quite a bit depending on the media you are working from. My suggestion is to render out five minutes worth of your program with and without 2-pass and see if you can tell a difference.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Peter Wright
    February 3, 2006 at 6:00 am
    Depends on the footage. If, for instance it’s a talking head with a still background, dual pass will make little difference. If, on the other hand, there are some fast moving or complex sequences mixed with some less moving sequences, the dual pass will allocate more resources where they are most needed, and you will end up with better quality overall for the same average bitrate.
