Activity › Forums › VEGAS Pro › Rendering Mp4
  • Rendering Mp4
    Posted by Cal North on September 27, 2011 at 3:58 pm
    Wow, I posted three days ago as I’m on deadline and the powers that be at CCow have not yet posted my question? Very bizarre.
    I desperately need info on the best rendering settings for MP4.
    I am on AVCHD and it must be exported as MP4.
    I find it all pretty confusing but have come up with one that works, it needs to be highest quality, playable on both Mac and PC and not a giant file size — although I know it will be big.
    I am also doing 16 bit even though some recommend 8 because it’s higher.
    I am wondering if there’s a better setting than AVCHD since that comes up m2s and I can’t do that so I manually change it to MP4.
    Also, I am rendering and then putting in rendered sections to render again — is MP4 the best format to use for that?
    I would really appreciate if this time my post was posted and welcome any advice on this. Thanks in advance!
    Mike Kujbida replied 15 years ago 2 Members · 1 Reply
  • Mike Kujbida
    September 28, 2011 at 1:33 am
    Choose “Sony AVC/MVC *.mp4, *.m2tsd, *.avc)” in the “Save as type” box.
    Once you do that, there are several Internet templates to choose from, depending on your needs.
    “Also, I am rendering and then putting in rendered sections to render again — is MP4 the best format to use for that?”
    I don’t use AVCHD but I’d render to the same file spec as the original files.
