Activity › Forums › Adobe After Effects › Rendering – Motion Blur and Field
  • Rendering – Motion Blur and Field
    Posted by Tornike Gelashvili on March 14, 2008 at 2:25 pm
    Hello,
    I would like to know if there are some rules on when should I use Motion blur when rendering and when should I turn on field rendering.
    As far ar I’ve experimented, eve though TV displaces image in interalces mode, it’s not necessary to render in field for TV. I use Motion blur on moving layers (sometimes on all of them) and the image gets nice and smooth, but a little blurred, compared to when rendering without motion blur and with fields.
    What if I render with both on?
    Could anyone please explain the technical part of it.
    Should I always render in field when making a video for TV?
    When should I and when should I not use motion blur or both together (MB and Fields)?
    Thank you.
    Jill Kennedy replied 17 years, 4 months ago 2 Members · 3 Replies
  • Tornike Gelashvili
    March 14, 2008 at 7:15 pm
    I see.
    But what about field rendering? Is it recommended, required or again a metter of taste? Because field rendering makes animation more live and technical than progressive scan rendering.
    As I understand nothing is required. Everything is a matter of taste. But could anyone explain the process of rendering a motion blurred motion with fields. I’m asking this because motion blur creates a progreessive like motion and field makes interlaced motion. So what happens? Is it not recommended?
    Sorry for asking this over and over. I really want to understand the actual process that happens during rendering.
    March 15, 2008 at 7:45 am
    Thank you Dave, that was exactly what I wanted to know. I experimeted with the animation rendered in different ways. I’ve finally understood on the practice, that motion blur is a matter of taste and Field is a matter of a technical specification.
    I have also noticed, that motion blur does not produce a progressive scan look when rendered witthout fields. In some cases the moving object gets jittery. It might me some problem with my settings or maybe I messed something up, but anyway, thanks a lot.
  • Jill Kennedy
    May 9, 2009 at 1:17 am
    Hi there,
    I am experiencing the same jittering when rendering motion blur with fields off in After Effects CS4. It is possible to render smooth motion with Fields off?
