Activity Forums Adobe After Effects Rendering : Media Encoder and purging every frame??
  • Rendering : Media Encoder and purging every frame??
    Posted by Tristan Summers on October 25, 2011 at 11:04 am
    If anyone has any tips on yhis it would help a lot…
    SOOOOO.
    I am rendering with ACCURATE anti-aliasing on Vector files.
    This causes rendering to crash if I do not purge every frame.
    IF
    I want to render in background using Media Encoder,
    CAN
    I get IT to purge every frame also?
    Does it follow the project settings?
    Or is this a different preference in Media Encoder?
    Tris
    Roland R. kahlenberg replied 14 years, 11 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    October 25, 2011 at 2:10 pm
    Hi Tristan, it sounds like you’re not on a 64-bit version of AE, where AE’s 32-bit versions may occasionally require a Purge every Frame setting upon rendering to get your timeline rendered.
    I doubt that AME has such a setting. It sounds like you’re loading your comp directly into AME. It looks like you’ll want to render out directly from AE, to a high-quality file and then feed this file into AME.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
