Activity Forums Adobe After Effects rendering masks
  • rendering masks
    Posted by Andrew Potter on August 8, 2011 at 3:15 pm
    Odd. I reopened an old project, made a few simple changes, and now the animated mask I created does not render. The mask previews properly, but does not render at all. It must be a render setting, but I can’t figure out which one. Ideas?? Thanx. After Effects 7.0
    Stefan Hinze replied 15 years, 1 month ago 2 Members · 4 Replies
  • Stefan Hinze
    August 8, 2011 at 3:32 pm
    is it set as a – Guide Layer ?
    (in the timeleine – right klick – Guide Layer)
    a GL will show in the work but not in der Render.
    (take a step back, to see the bigger picture)
  • Andrew Potter
    August 8, 2011 at 3:43 pm
    Thanks, Stefan. I don’t think AE 7.0 has guide layers in the timeline. I can switch guide layers on and off in the render queue, but it doesn’t remedy.
  • Andrew Potter
    August 8, 2011 at 4:44 pm
    Thanks, Dave. You’ve bailed me out before…. I figured it out. I don’t understand it, but I figured it out.
    And no, it’s not from an even earlier version. AE7 was cutting edge in it’s day, but I can’t keep up.
  • Stefan Hinze
    August 8, 2011 at 4:46 pm
    could you tell us what it was?
