Rendering makes footage look worse!!
I freelance for a lady who produces wedding videos. At the end of each video there is a split screen finale where all the clips are scaled down to 40% and played side by side. Everytime I output my DVD she makes the same comment “severe stepladdering during finale”
I’m capturing from mini DV via firewire, my settings are DV NTSC. My sequences are the same. I export as a Quicktime movie and then burn in DVDSP or encode in compressor and then burn, but I don’t see any improvement in the quality. I’ve read all the post and tried changing the motion filter tab, positioning on even integers etc. Yesterday I changed the aspect ratio I think (it’s the first option under the sequence settings tab) from 4:3 to 3:2 or vice versa. The hold sequence turned red, which I expected b/c my clip and sequence settings no longer matched. but when I would scrub through the sequence the scaled video looked absolutely gorgeous! So I thought yes, I finally found something that works! But then I rendered. And my beautiful footage turned into pure unadulterated crap. So my round about question is, how can I keep the crisp looking video after rendering???? And why is rendering making the situation worse? Any suggestions would be helpful.
