Activity Forums Maxon Cinema 4D rendering makes 16 passes for single image
  • rendering makes 16 passes for single image
    Posted by Graham Quince on October 8, 2007 at 8:51 am
    Hi everyone
    I’m hoping I’ve messed up. I’m trying to render out a fast moving animation in C4D r10 with a couple of multipass objects. I’ve also wanted to make use of depth of field, lens effects, object glow and scene motion blur.
    I’m a relative newcomer to C4d, so apologies right now if I’m getting what I asked for, but I was quite surpised when each file took 16 passes to produce. I used to have C4d r9 and don’t remember the effects tab in render settings. Each file seemed to take 3 passes (one for the video and one each for the multipass)
    The result is that my overnight render was only a third of the way through the entire sequence (thank goodness I was using image sequences rather than a single file). Is there something I can be doing to speed up the process, or are these passes the result of everything I’m asking it to do.
    Graham
    Samir Kharchi replied 18 years, 11 months ago 2 Members · 3 Replies
  • Samir Kharchi
    October 8, 2007 at 9:02 am
  • Graham Quince
    October 8, 2007 at 10:15 am
    Thanks very much for the speedy reply. It was right there staring me in the face as soon as you said.
    Graham
  • Samir Kharchi
    October 8, 2007 at 11:16 am
