Activity › Forums › Adobe After Effects › rendering lumetri before a noise pass
  • rendering lumetri before a noise pass
    Posted by Mark Foerster on July 14, 2019 at 6:08 pm
    Hello All, I have a lot of noise reduction to do (neat) and when combined with lumetri it really slows the timeline down. I’d like to prerender the lumetri adjustments – and then apply noise reduction – yet keeping all the clips available on the timeline for timing tweaks and the like..My usual Gorilla technique is to output the video layer and roundtrip it back in – that makes everything spring fresh again, but in this case I’d like the 200 or so clips available for adjustments..
    Thanking you in advance
    Mark Foerster
    Toronto
    Mark Foerster replied 7 years, 2 months ago 2 Members · 2 Replies
  • Walter Soyka
    July 18, 2019 at 2:50 am
    I’d suggest doing the noise reduction first, then coloring afterwards — you should get better NR results, better keying/secondaries when coloring, and I’d think you’d be more likely to want to tweak color after the fact than you would want to tweak noise reduction.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Mark Foerster
    July 18, 2019 at 3:10 am
    Thanks Walter!
