Activity Forums VEGAS Pro Rendering long projects on a laptop
  • Rendering long projects on a laptop
    Posted by Mark Van der berg on April 19, 2015 at 1:17 pm
    Hey people!
    I was just wondering if anyone has any experience with rendering long movies (In this case a 106 minute project) on a laptop? It’s not that my laptop isn’t powerful enough (Intel i7 processor with 8gb of RAM), but that I am afraid of the heat. Does anyone know if this could be harmful to my laptop, or if theres a way to make Sony Vegas render slower to reduce the strain on my machine? Can it be done AT ALL?
    I’m running Windows 8.1 if that helps, the project will be in XDCAM EX MP4 which admittely are also ENORMOUS files..
    Any help would be appreciated!
    David Norman replied 11 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    April 19, 2015 at 7:54 pm
    Nothing is wrong to do everything on a good laptop Mark.
    Laptop is all i use!
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Mark Van der berg
    April 19, 2015 at 8:00 pm
    Hey Mark- thanks for the response! One question: is your laptop fine like that without a cooling set or anything?
  • Steve Rhoden
    April 19, 2015 at 8:31 pm
    Yep! Just an average off the shelf powerful laptop with no
    cooling set or anything.
  • Aaron Star
    April 20, 2015 at 2:16 am
    If you are worried about heat, and you have an air compressor, blow out the cool fins. Some disassembly may be required, some laptops may not require this. Use a screw driver to hold the fan from spinning to fast. The heat fins inside most laptops look like a clogged dryer lint screen after about 6 months. Doing this every 6 months to a year can improve laptop stability, longevity, and reduce fan noise greatly.
    Rendering on a laptop should not be any different than a desktop, only much slower generally.
  • Bob Peterson
    April 20, 2015 at 5:51 pm
    The laptop most likely has the ability to shut down before it gets hot enough to damage itself. My daughter has a Toshiba laptop that gradually built up dust and would overheat while she was playing World of Warcraft. It would simply shut down, and that told her that it had overheated. It would start again just fine with no evidence of any lasting damage.
  • Kevin Mccarthy
    April 20, 2015 at 7:48 pm
    I use my laptop at least 90% of the time. It is also an I7 with 8GB and I Have never had a problem with even 3plus hour renders. I do use a cooler fan on all my laptops to off-set any problems.
  • David Norman
    May 18, 2015 at 12:20 am
    i routinely have rendered long projects 90+ minutes. i7 doesnt mean a ton either since there are dual core nad quad core variants, ultra low power i7 and desktop i7 in notebooks.
    as for heat it is a non-issue as long as it is not on your lap the whole time, could decrease your ability to have a child 🙂
    i bought a dell xps 15 specifically for rendering since it has a true quadcore i7 while being thin and portable.
    best of luck, i do find it challenging to work on projects with 3D plugins and titles without real desktop class horsepower
    Dell XPS 15″ 9350 i7, 512gb SSD, Nvidia 750m
    Intel i7 3930K, R9 290, 32gb, 2xRAID0 Intel 240gb SSD, 2x2TB WD Green, 3×23″ Samsung LCDs
    https://youtube.com/adidas4275
