Activity Forums Adobe After Effects Rendering Issues on CS5
  • Rendering Issues on CS5
    Posted by Adam Lewen on September 19, 2010 at 7:15 pm
    Hello!
    I am trying for sometime now to figure out what the heck is causing my system to “Not Respond” or crash when rendering a 7 Min HD Clip.
    The clip has no effects at all. Even when rendering it out to a Proxy, After will choke until a hard reset 🙁
    I am working on a pretty fresh PC with these features:
    8GB RAM
    2TB HD
    GTX 470 Graphic Card.
    I am sure the simple renders I am trying are simple for this machine.
    I have also been playing around for a long time with the Memory and Multiprocessing… (enable/disable/2 out of 8 cores reserved for other apps/ nothing… really been trying every possible way. I think)
    I Even tried deleting the Preferences Folder, as suggested here:
    https://forums.adobe.com/message/2817632 , with no luck…
    Is there anybody out there who suffered from a similar problem?
    Please let me know. I hope not to run a fresh set up.
    Thanks. and excuse the info bombing 🙂
    Adam Lewen replied 15 years, 10 months ago 2 Members · 3 Replies
  • Todd Kopriva
    September 19, 2010 at 8:29 pm
    Have you installed the After Effects CS5 (10.0.1) update? That update fixes a lot of problems.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Adam Lewen
    September 20, 2010 at 6:32 am
    I will ask. I think we did not.
    I will post soon if it was resolved.
    I really hope an update will be the cure.
    Thank you.
  • Adam Lewen
    October 10, 2010 at 8:53 pm
    Hello again. I was away but now I am back, and back to my problem…
    I just realized I posted ‘fresh’ post a couple of hours ago, about the same issue I never resolved here. I apologize for the double post, but I thought this is the right to continue! (Can’t seem to delete a post after 30 minutes of it being online)
    As for my problem:
    I understand 8GB of RAM is not a lot, but i believe that a clean video with no effects and no other applications in the background should at least be able to render out a proxy so I could work…
    I will try and play around with more setting.
    P.S
    The software here is updated.
    If anyone has any more suggestions, again
    Can’t seem to render Quick Time HD file to a 1/4 of it’s quality, in QT Photo JPG or Sorenson.
    I am a bit stuck on this one. I believe I was able to do so with older machines on 32bit.
    Adam
