Activity Forums Adobe Premiere Pro rendering issues & media offline
  • rendering issues & media offline
    Posted by Alastair Pickering on September 8, 2008 at 9:29 pm
    Premiere Pro (Trial) keeps crashing when i try to file>export>movie>dv avi.
    The sequence is short (less than a minute), though the speed/durations are all changed from normal time, from 2% to 6000%. it is yet to be changed in AE.
    I’m just stuck on what is crashing PPro.
    And sometimes the red bars above the clips are gone, and “media offline” appears. I can’t quite figure out why that is happening. “media offline” is not involved with the same sequence I am having rendering difficulties with.
    I sure could use some help. =/
    Eddie Lotter replied 17 years, 12 months ago 2 Members · 1 Reply
  • Eddie Lotter
    September 8, 2008 at 10:08 pm
    The trial version does not support mpeg formats of any kind. I’m guessing your AVI file uses an mpeg based codec. Use a utility like GSpot to determine the codecs used in your AVI files.
    You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
