Activity › Forums › Apple Final Cut Pro Legacy › Rendering issues in Final Cut PRo 5.0.4
  • Rendering issues in Final Cut PRo 5.0.4
    Posted by Ryan Laurita on August 1, 2007 at 6:07 pm
    Hi, I am running into an issue with Fianl Cut Pro 5.0.4 not rendering any of my edited content. I go to sequence/render all and all I get is the “common” dialogue box flashes for about 1/8th of a second and goes away…. and voila… Noting happens. I still can’t see my edited content rendered. Does anybody know what is going on with this, and if so could you help me, please.
    Ryan
    Rafael Amador replied 19 years, 2 months ago 3 Members · 2 Replies
  • Russell Lasson
    August 1, 2007 at 6:47 pm
    I’ve only seen this happen when the content that you’re trying to render doesn’t have a check mark by it when you go to sequence – render all.
    Most of the time I work with pretty much everything selected so I know how it will look when it’s final.
    -Russ
  • Rafael Amador
    August 2, 2007 at 6:16 am
    Ryan,
    This question can be silly, but for any chance have you got an IN and OUT points set in your sequence? If so FC will only render in between the marks.
    Rafael
