Activity Forums Adobe After Effects RENDERING ISSUES
  • RENDERING ISSUES
    Posted by Cody Howard on December 21, 2007 at 4:29 am
    Whats up guys and gals. I’m having a hell of a time trying to render my animated clip as 16:9 . I’ve tried everything…and the only thing that exports as 16:9 is when i change the composite settings to “HDV/HDTV 720” option. I’m making this intro and then importing it and further editing in Vegas. Well when i import anything besides a “HDV/HDTV 720” clip in Vegas, they are smashed down to 3:4. Could someone please tell me what i’m doing wrong? Thanks in advance!!
    1.yes i am using the “render queue”
    2.yes i have tried the DV Widescreen Composite Settings
    3. Thanks Again!!
    P.S….when i render a DV Widescreen Clip, After Effects is the only program that reads it as a “WideScreen 16:9” clip! agggghh!
    Cody Howard replied 18 years, 9 months ago 2 Members · 3 Replies
  • Darby Edelen
    December 21, 2007 at 4:46 am
    It sounds to me like you need to tell Vegas that it is 16:9 footage. Both NTSC DV and NTSC DV Widescreen are 720×480 pixels, the difference is that 4:3 NTSC displays have a 0.9 pixel aspect ratio (effectively squeezing the image to 90% of its square pixel width for display) and 16:9 NTSC displays have a 1.2 pixel aspect ratio (effectively stretching the image to 120% of its square pixel width for display).
    Is there somewhere in Vegas that you can set a pixel aspect ratio, or tell Vegas that the footage is ‘anamorphic’ or 16:9?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Cody Howard
    December 21, 2007 at 4:52 am
    haven’t found it….i’m looking everywhere for that. The wierd thing is..is that Quicktime doesn’t even pick it up as 16:9! So i’m copying and pasting this in the Vegas forum too. But the search of a cure is still on! Thx
  • Cody Howard
    December 21, 2007 at 4:55 am
    THANK YOU THANK YOU THANK YOU. I went a bit deeper into the media, once it was in Vegas…i right clicked on the footage…and selected the the correct pixel ratio. Thanks again. Problem solved
    Gracias
