Activity Forums Apple Final Cut Pro Legacy Rendering Issues
  • Rendering Issues
    Posted by Jim Murphy on January 11, 2012 at 5:51 pm
    So in a nutshell i am working on a FCP project off 2 different Macs… one Mac Quad Core and one is an older Macbook Pro. when I copy the entire project folder to an external drive and bring it to the Macbook Pro, everything that was rendered on the Mac Pro needs to be re-rendered and takes forever.
    Other then the Macbook Pro being a little older, what else could cause me to re-render the sequences and why such a painfully slow render time?
    Tony Brittan replied 14 years, 8 months ago 2 Members · 3 Replies
  • Jim Murphy
    January 11, 2012 at 6:12 pm
    I would have to check… in the System settings all is set to read/write at the specific folder the project is in, however I would have to check to see where FCP is actually putting the render files.
    If it is writing the render files to a different location, can I copy that Render folder to the external hard drive and reconnect if needed?
  • Jim Murphy
    January 11, 2012 at 6:34 pm
    ok. what if I change the location of the Render Folder in the settings to write them to a folder on the external drive… will that then remedy the re-rendering on the second machine so long as the second machine is set the same way (to look for the render folder on the external drive)? Obviously i would have to initially re render the sequences but after that the second machine should not need to render again. Is this correct?
  • Tony Brittan
    January 11, 2012 at 8:17 pm
    And doesn’t the new drive also have be named the exact same as the old one?
