Activity Forums VEGAS Pro Rendering issue with MPG2 files..
  • Rendering issue with MPG2 files..
    Posted by J-p Desrochers on November 22, 2005 at 1:59 pm
    Since I’m relatively new in the video editing
    I have a question about rendering with Vegas6.
    I have 2 MPG2 files to edit & mix for a final
    edited show I recorded last year.
    2 separate cameras, 2 MPG2 files.
    Since I started recording video files with a PC
    only then I didn’t know
    (and didn’t have the good hardware to do it nether)
    it’s better not record in MPG2 files for source files
    to be edited since they are too much compressed
    and they will have to be again on the rendering
    process..
    Well now I’m stuck with those MPG2 files
    and I don’t know how to set the rendering parameters
    to ‘tell’ Vegas not to recompress when possible..
    Those MPG files were recorded with an ATI ALL IN WONDER
    card with the ATI capture installed back then.
    That ATI capture software would only permit
    recording in MPG2 format so…
    Since I don’t have any utility soft to tell me
    the file’s properties (video bit rates, audio type/rates,
    Vegas doesn’t tell the video bit rate of my source files)
    this could be handy so I could set the render parameters
    to be the same as the source MPG2 files to keep
    from recompressing??
    Sorry for the long explaination.
    Any help.
    Terje A. bergesen replied 20 years, 10 months ago 4 Members · 5 Replies
  • Gary Kleiner
    November 22, 2005 at 3:21 pm
    Vegas will always recompress your Mpeg2 files. ( I hoope this changes some day). In the meantime you should look into software that is made for Mpeg editing such as Womble’s Mpeg Video Wizard. It works as you have described by recomressing only transitions, etc.
    Gary
  • Edward Troxel
    November 22, 2005 at 3:24 pm
    When starting with MPEG2 files – EVERY FRAME will be decompressed. There is no way for Vegas to go from MPEG2 to MPEG2 without decompressing and recompressing every frame. So there’s no way “to ‘tell’ Vegas not to recompress when possible“.
    There are some programs that will let you split and combine MPEG2 files, though. Take a look at Womble. This would let you do “cuts only” editing and would also prevent the recompression.
    Edward Troxel
    JETDV Scripts
  • J-p Desrochers
    November 22, 2005 at 4:20 pm
    Ok thanks.
    Can Womble edit 2 MPG’s video tracks
    at the same time to enable ‘camera switching’
    like final result?
  • Gary Kleiner
    November 22, 2005 at 4:30 pm
    No.
    Gary
  • Terje A. bergesen
    November 22, 2005 at 6:57 pm
    Having used a few different NLEs lately, this is the one area where I would recommend another package over Vegas. Please note this is the ONLY reason for recommending this, but Ulead Media Studio Pro does a reasonable job of allowing you to edit MPEG-2 and only recompress what is needed. In general I wouldn’t recommend MSPro over Vegas, but in this one and very particular case, Ulead does indeed do it better than Vegas.
    Terje A. Bergesen
